[quote=“Ciceron”]thank you david for the prompte reply, will test it tomorrow and get back to you ASAP!
All the above worked, but:
no playlist, I see my vmb4ry, but how could I interact…?
http://www.aknari.com/sc.jpg[/quote]
I can’t reach the server where the image’s on. I’m not to familiar with VelbusSocket, but I believe that you can’t interact with the modules listed in the interface. To interact with channels of certain modules you have to add the necessary data in the ‘data.xml’ file in the same directory. This will make the commands for each channel show up in the uppermost list in VelbusSocket.exe. You can then activate or deactivate each channel by clicking the right command. You can visit code.google.com/p/flexvelbussocket/ for more info on the ‘data.xml’ file.
Or did you adapt the xml-file already? If you can’t figure it out, you can ask here again and I’ll try and explain that bit too.
EDIT:
Now I see the picture. As I figured, you didn’t adapt the xml-file. Visit the website, visit this thread, give it a try and if it didn’t work we’ll try to clarify things for you.
