Duct split heating and cooling system
Is that possible to control the duct split system using velbuslink? as I read about that we should use a Global Caché iTach Flex IP and switch network and configure it in homecenter, but i’m not sure about that and I need some more information about it.
any help?
Thanks.
What kind of options do you have to control your ducting system? Is it only possible to control via IR ?
I have a client who uses a couple of 10v outputs from a VMB4DC to move the louvres in his air flow cooling system, which have actions linking the Thermostats in glass panels.
just change the heating and cooling mode and can set the temperature using homecenter application.
the system has the remote control which work via IR and on/off key on each split.
That’s great news.
So just need to set up the actions / logic HomeCentre to link cooling (and fan speed using Thermostat alarms) to the correct IR command.
