Openhab velbus items
Does anyone know there if there is a .items configuration example out there? I have the most basic things working here like dimmers switches and temperatures. But wat i need is a status indicator from a contact / input.
i belief it is the “contact” integer but i don’t know how te implement the correct line :slight_smile:
Here a snippet of my items file
I’m no expert, I think you’ll find that Channels can’t be used directly in a UI.
If you want to show the status of a Channel, you’ll have to use a rule to change the state of a virtual Item.
Something like ----
rule "Switch on"
when
     Channel 'velbus:vmb7in:c5053467:0B:input#CH1' triggered PRESSED
then
 	Virtual_Switch.sendCommand(ON)
end
rule "Switch off"
when
     Channel 'velbus:vmb7in:c5053467:0B:input#CH1' triggered RELEASED
then
 	Virtual_Switch.sendCommand(OFF)
end
FYI
Try these kind of questions in the OpenHab2 forum, you’ll get many more answers :wink:
https://community.openhab.org
I’ll try the openhab forum tomorrow
Thanks Stuart :wink:
I did a quick search for you and found this…
