Philips Hue integration
Does anybody have experience with Hue integration?
It would be nice to trigger Hue lighs/scenes/… with Velbus controllers.
Any thoughts on this?
Hello
As this is a very old post, I assume you’ve found a solution?
If so, what did you use?
A solution today would be to use something like OpenRemote to translate the events within your Velbus network into actions in your Philips Hue devices.
Philips Hue in OpenRemote - openremote.org/display/docs/OpenRemote+2.0+How+To±+Philips+Hue
Velbus in OpenRemote - openremote.org/display/docs/ … o±+Velbus
Sample rule to trigger events :-
[code]package org.openremote.controller.protocol;
global org.openremote.controller.statuscache.CommandFacade execute;
import java.util.*;
rule “GPO button 4” when
Event( source == “GPO_Button_4”, value == “pressed” )
then
    execute.command("Philips _Hue_RGB", "ff0000"); // Uncomment to send command
end
[/code]
Any updates on this?
There must be some thinkers having a solution for this? :slight_smile:
In the meantime I have my own implementation: I’ve created a NodeJS solution running on a Raspberry Pi.
The VMB1USB is plugged in the Pi and communicates over a serial connection. It also is connected to the internet with an ethernet cable, allowing to communicate with the Philips Hue API.
Then I have a few very basic classes that can listen to commands over the bus and send actions to Hue.
I’m working on a better implementation right now but as a proof of concept I’m very happy with it: it runs for 3 months nonstop and it never failed up till now! Rock-solid: I never had to restart it :wink:
Here’s the git: https://github.com/gertst/VelbusHuePi
Does anybody know of an existing javascript/nodejs API for Velbus? I wrote an API in Actionscript, 7 years ago, so doing that over in JS is not that difficult. But we don’t want to reinvent the wheel again, do we? :stuck_out_tongue:
