Hello again.
I was now trying to add devices, and for what I could find:
VMB4RYNO
Module address: 00
Relay: 1
Address in Velbus plugin: 00-1
Is this correct?
When I try to toggle the widget, I get the error message:
[quote]RINOR : ‘No data or timeout on getting command response’
(/rinor/api/command/velbus/00-1/)[/quote]
Looks like it’s detecting a device that it’s not recognized.
The device at address 49 (0x31) is a VMBLCDWB (LCD Push-Button Panel). In fact, this device has 4 addresses: 49, 50, 51, 52 (0x31, 0x32, 0x33, 0x34).
After that, I have a VBMB7IN at address 64 (0x40).
Is there a way to bypass the detection at some addresses?
Logfile:
[code]2013-09-17 15:13:25,015 domogik-velbus INFO Daemonize plugin velbus
2013-09-17 15:13:25,035 domogik-velbus INFO ----------------------------------
2013-09-17 15:13:25,040 domogik-velbus INFO Starting plugin ‘velbus’ (new manager instance)
2013-09-17 15:13:25,578 domogik-velbus INFO Try to open VELBUS: /dev/ttyACM0
2013-09-17 15:13:25,592 domogik-velbus INFO write deamon
2013-09-17 15:13:25,597 domogik-velbus INFO VELBUS opened
2013-09-17 15:13:25,600 domogik-velbus INFO Starting the bus scan
2013-09-17 15:13:25,602 domogik-velbus INFO write packet
2013-09-17 15:13:25,633 domogik-velbus INFO write packet
2013-09-17 15:13:25,636 domogik-velbus INFO write packet
2013-09-17 15:13:25,638 domogik-velbus INFO write packet
2013-09-17 15:13:25,640 domogik-velbus INFO write packet
2013-09-17 15:13:25,654 domogik-velbus INFO write packet
2013-09-17 15:13:25,657 domogik-velbus INFO write packet
2013-09-17 15:13:25,665 domogik-velbus INFO write packet
2013-09-17 15:13:25,669 domogik-velbus INFO write packet
2013-09-17 15:13:25,677 domogik-velbus INFO write packet
2013-09-17 15:13:25,679 domogik-velbus INFO write packet
2013-09-17 15:13:25,681 domogik-velbus INFO write packet
2013-09-17 15:13:25,694 domogik-velbus INFO write packet
2013-09-17 15:13:25,696 domogik-velbus INFO write packet
2013-09-17 15:13:25,699 domogik-velbus INFO write packet
2013-09-17 15:13:25,701 domogik-velbus INFO write packet
2013-09-17 15:13:25,710 domogik-velbus INFO write packet
2013-09-17 15:13:25,723 domogik-velbus INFO write packet
2013-09-17 15:13:25,727 domogik-velbus INFO write packet
2013-09-17 15:13:25,730 domogik-velbus INFO write packet
2013-09-17 15:13:25,732 domogik-velbus INFO write packet
2013-09-17 15:13:25,739 domogik-velbus INFO write packet
2013-09-17 15:13:25,741 domogik-velbus INFO write packet
2013-09-17 15:13:25,754 domogik-velbus INFO write packet
2013-09-17 15:13:25,756 domogik-velbus INFO write packet
2013-09-17 15:13:25,758 domogik-velbus INFO write packet
2013-09-17 15:13:25,761 domogik-velbus INFO write packet
2013-09-17 15:13:25,773 domogik-velbus INFO write packet
2013-09-17 15:13:25,776 domogik-velbus INFO write packet
2013-09-17 15:13:25,778 domogik-velbus INFO write packet
2013-09-17 15:13:25,780 domogik-velbus INFO write packet
2013-09-17 15:13:25,794 domogik-velbus INFO write packet
2013-09-17 15:13:25,797 domogik-velbus INFO write packet
2013-09-17 15:13:25,805 domogik-velbus INFO write packet
2013-09-17 15:13:25,811 domogik-velbus INFO write packet
2013-09-17 15:13:25,813 domogik-velbus INFO write packet
2013-09-17 15:13:25,816 domogik-velbus INFO write packet
2013-09-17 15:13:25,818 domogik-velbus INFO write packet
2013-09-17 15:13:25,835 domogik-velbus INFO write packet
2013-09-17 15:13:25,837 domogik-velbus INFO write packet
2013-09-17 15:13:25,839 domogik-velbus INFO write packet
2013-09-17 15:13:25,842 domogik-velbus INFO write packet
2013-09-17 15:13:25,851 domogik-velbus INFO write packet
2013-09-17 15:13:25,854 domogik-velbus INFO write packet
2013-09-17 15:13:25,864 domogik-velbus INFO write packet
2013-09-17 15:13:25,867 domogik-velbus INFO write packet
2013-09-17 15:13:25,874 domogik-velbus INFO write packet
2013-09-17 15:13:25,876 domogik-velbus INFO write packet
2013-09-17 15:13:25,879 domogik-velbus INFO write packet
2013-09-17 15:13:25,881 domogik-velbus INFO write packet
2013-09-17 15:13:25,898 domogik-velbus INFO write packet
2013-09-17 15:13:25,900 domogik-velbus INFO write packet
2013-09-17 15:13:25,913 domogik-velbus INFO write packet
2013-09-17 15:13:25,915 domogik-velbus INFO write packet
2013-09-17 15:13:25,934 domogik-velbus INFO write packet
2013-09-17 15:13:25,944 domogik-velbus INFO write packet
2013-09-17 15:13:25,946 domogik-velbus INFO write packet
2013-09-17 15:13:25,957 domogik-velbus INFO write packet
2013-09-17 15:13:25,959 domogik-velbus INFO write packet
2013-09-17 15:13:25,962 domogik-velbus INFO write packet
2013-09-17 15:13:25,986 domogik-velbus INFO write packet
2013-09-17 15:13:25,989 domogik-velbus INFO write packet
2013-09-17 15:13:25,995 domogik-velbus INFO write packet
2013-09-17 15:13:26,020 domogik-velbus INFO write packet
2013-09-17 15:13:26,023 domogik-velbus INFO write packet
2013-09-17 15:13:26,026 domogik-velbus INFO write packet
2013-09-17 15:13:26,028 domogik-velbus INFO write packet
2013-09-17 15:13:26,045 domogik-velbus INFO write packet
2013-09-17 15:13:26,056 domogik-velbus INFO write packet
2013-09-17 15:13:26,063 domogik-velbus INFO write packet
2013-09-17 15:13:26,066 domogik-velbus INFO write packet
2013-09-17 15:13:26,076 domogik-velbus INFO write packet
2013-09-17 15:13:26,078 domogik-velbus INFO write packet
2013-09-17 15:13:26,080 domogik-velbus INFO write packet
2013-09-17 15:13:26,103 domogik-velbus INFO write packet
2013-09-17 15:13:26,106 domogik-velbus INFO write packet
2013-09-17 15:13:26,108 domogik-velbus INFO write packet
2013-09-17 15:13:26,110 domogik-velbus INFO write packet
2013-09-17 15:13:26,133 domogik-velbus INFO write packet
2013-09-17 15:13:26,173 domogik-velbus INFO write packet
2013-09-17 15:13:26,175 domogik-velbus INFO write packet
2013-09-17 15:13:26,178 domogik-velbus INFO write packet
2013-09-17 15:13:26,180 domogik-velbus INFO write packet
2013-09-17 15:13:26,182 domogik-velbus INFO write packet
2013-09-17 15:13:26,214 domogik-velbus INFO write packet
2013-09-17 15:13:26,217 domogik-velbus INFO write packet
2013-09-17 15:13:26,219 domogik-velbus INFO write packet
2013-09-17 15:13:26,233 domogik-velbus INFO write packet
2013-09-17 15:13:26,235 domogik-velbus INFO write packet
2013-09-17 15:13:26,237 domogik-velbus INFO write packet
2013-09-17 15:13:26,263 domogik-velbus INFO write packet
2013-09-17 15:13:26,267 domogik-velbus INFO write packet
2013-09-17 15:13:26,270 domogik-velbus INFO write packet
2013-09-17 15:13:26,293 domogik-velbus INFO write packet
2013-09-17 15:13:26,295 domogik-velbus INFO write packet
2013-09-17 15:13:26,298 domogik-velbus INFO write packet
2013-09-17 15:13:26,300 domogik-velbus INFO write packet
2013-09-17 15:13:26,323 domogik-velbus INFO write packet
2013-09-17 15:13:26,329 domogik-velbus INFO write packet
2013-09-17 15:13:26,332 domogik-velbus INFO write packet
2013-09-17 15:13:26,336 domogik-velbus INFO write packet
2013-09-17 15:13:26,346 domogik-velbus INFO write packet
2013-09-17 15:13:26,348 domogik-velbus INFO write packet
2013-09-17 15:13:26,350 domogik-velbus INFO write packet
2013-09-17 15:13:26,364 domogik-velbus INFO write packet
2013-09-17 15:13:26,367 domogik-velbus INFO write packet
2013-09-17 15:13:26,369 domogik-velbus INFO write packet
2013-09-17 15:13:26,371 domogik-velbus INFO write packet
2013-09-17 15:13:26,380 domogik-velbus INFO write packet
2013-09-17 15:13:26,390 domogik-velbus INFO write packet
2013-09-17 15:13:26,393 domogik-velbus INFO write packet
2013-09-17 15:13:26,404 domogik-velbus INFO write packet
2013-09-17 15:13:26,406 domogik-velbus INFO write packet
2013-09-17 15:13:26,409 domogik-velbus INFO write packet
2013-09-17 15:13:26,411 domogik-velbus INFO write packet
2013-09-17 15:13:26,424 domogik-velbus INFO write packet
2013-09-17 15:13:26,427 domogik-velbus INFO write packet
2013-09-17 15:13:26,429 domogik-velbus INFO write packet
2013-09-17 15:13:26,431 domogik-velbus INFO write packet
2013-09-17 15:13:26,441 domogik-velbus INFO write packet
2013-09-17 15:13:26,447 domogik-velbus INFO write packet
2013-09-17 15:13:26,450 domogik-velbus INFO write packet
2013-09-17 15:13:26,466 domogik-velbus INFO write packet
2013-09-17 15:13:26,469 domogik-velbus INFO write packet
2013-09-17 15:13:26,471 domogik-velbus INFO write packet
2013-09-17 15:13:26,474 domogik-velbus INFO write packet
2013-09-17 15:13:26,483 domogik-velbus INFO write packet
2013-09-17 15:13:26,485 domogik-velbus INFO write packet
2013-09-17 15:13:26,487 domogik-velbus INFO write packet
2013-09-17 15:13:26,490 domogik-velbus INFO write packet
2013-09-17 15:13:26,492 domogik-velbus INFO write packet
2013-09-17 15:13:26,508 domogik-velbus INFO write packet
2013-09-17 15:13:26,510 domogik-velbus INFO write packet
2013-09-17 15:13:26,523 domogik-velbus INFO write packet
2013-09-17 15:13:26,528 domogik-velbus INFO write packet
2013-09-17 15:13:26,544 domogik-velbus INFO write packet
2013-09-17 15:13:26,547 domogik-velbus INFO write packet
2013-09-17 15:13:26,549 domogik-velbus INFO write packet
2013-09-17 15:13:26,551 domogik-velbus INFO write packet
2013-09-17 15:13:26,554 domogik-velbus INFO write packet
2013-09-17 15:13:26,563 domogik-velbus INFO write packet
2013-09-17 15:13:26,565 domogik-velbus INFO write packet
2013-09-17 15:13:26,567 domogik-velbus INFO write packet
2013-09-17 15:13:26,570 domogik-velbus INFO write packet
2013-09-17 15:13:26,572 domogik-velbus INFO write packet
2013-09-17 15:13:26,581 domogik-velbus INFO write packet
2013-09-17 15:13:26,595 domogik-velbus INFO write packet
2013-09-17 15:13:26,598 domogik-velbus INFO write packet
2013-09-17 15:13:26,601 domogik-velbus INFO write packet
2013-09-17 15:13:26,607 domogik-velbus INFO write packet
2013-09-17 15:13:26,610 domogik-velbus INFO write packet
2013-09-17 15:13:26,612 domogik-velbus INFO write packet
2013-09-17 15:13:26,625 domogik-velbus INFO write packet
2013-09-17 15:13:26,627 domogik-velbus INFO write packet
2013-09-17 15:13:26,630 domogik-velbus INFO write packet
2013-09-17 15:13:26,632 domogik-velbus INFO write packet
2013-09-17 15:13:26,641 domogik-velbus INFO write packet
2013-09-17 15:13:26,644 domogik-velbus INFO write packet
2013-09-17 15:13:26,646 domogik-velbus INFO write packet
2013-09-17 15:13:26,664 domogik-velbus INFO write packet
2013-09-17 15:13:26,667 domogik-velbus INFO write packet
2013-09-17 15:13:26,670 domogik-velbus INFO write packet
2013-09-17 15:13:26,678 domogik-velbus INFO write packet
2013-09-17 15:13:26,680 domogik-velbus INFO write packet
2013-09-17 15:13:26,687 domogik-velbus INFO write packet
2013-09-17 15:13:26,689 domogik-velbus INFO write packet
2013-09-17 15:13:26,692 domogik-velbus INFO write packet
2013-09-17 15:13:26,705 domogik-velbus INFO write packet
2013-09-17 15:13:26,707 domogik-velbus INFO write packet
2013-09-17 15:13:26,709 domogik-velbus INFO write packet
2013-09-17 15:13:26,711 domogik-velbus INFO write packet
2013-09-17 15:13:26,726 domogik-velbus INFO write packet
2013-09-17 15:13:26,731 domogik-velbus INFO write packet
2013-09-17 15:13:26,733 domogik-velbus INFO write packet
2013-09-17 15:13:26,741 domogik-velbus INFO write packet
2013-09-17 15:13:26,748 domogik-velbus INFO write packet
2013-09-17 15:13:26,751 domogik-velbus INFO write packet
2013-09-17 15:13:26,763 domogik-velbus INFO write packet
2013-09-17 15:13:26,766 domogik-velbus INFO write packet
2013-09-17 15:13:26,768 domogik-velbus INFO write packet
2013-09-17 15:13:26,770 domogik-velbus INFO write packet
2013-09-17 15:13:26,779 domogik-velbus INFO write packet
2013-09-17 15:13:26,781 domogik-velbus INFO write packet
2013-09-17 15:13:26,794 domogik-velbus INFO write packet
2013-09-17 15:13:26,796 domogik-velbus INFO write packet
2013-09-17 15:13:26,798 domogik-velbus INFO write packet
2013-09-17 15:13:26,814 domogik-velbus INFO write packet
2013-09-17 15:13:26,816 domogik-velbus INFO write packet
2013-09-17 15:13:26,819 domogik-velbus INFO write packet
2013-09-17 15:13:26,821 domogik-velbus INFO write packet
2013-09-17 15:13:26,824 domogik-velbus INFO write packet
2013-09-17 15:13:26,826 domogik-velbus INFO write packet
2013-09-17 15:13:26,838 domogik-velbus INFO write packet
2013-09-17 15:13:26,841 domogik-velbus INFO write packet
2013-09-17 15:13:26,851 domogik-velbus INFO write packet
2013-09-17 15:13:26,863 domogik-velbus INFO write packet
2013-09-17 15:13:26,865 domogik-velbus INFO write packet
2013-09-17 15:13:26,868 domogik-velbus INFO write packet
2013-09-17 15:13:26,870 domogik-velbus INFO write packet
2013-09-17 15:13:26,877 domogik-velbus INFO write packet
2013-09-17 15:13:26,883 domogik-velbus INFO write packet
2013-09-17 15:13:26,885 domogik-velbus INFO write packet
2013-09-17 15:13:26,888 domogik-velbus INFO write packet
2013-09-17 15:13:26,890 domogik-velbus INFO write packet
2013-09-17 15:13:26,902 domogik-velbus INFO write packet
2013-09-17 15:13:26,905 domogik-velbus INFO write packet
2013-09-17 15:13:26,907 domogik-velbus INFO write packet
2013-09-17 15:13:26,909 domogik-velbus INFO write packet
2013-09-17 15:13:26,938 domogik-velbus INFO write packet
2013-09-17 15:13:26,952 domogik-velbus INFO write packet
2013-09-17 15:13:26,981 domogik-velbus INFO write packet
2013-09-17 15:13:26,996 domogik-velbus INFO write packet
2013-09-17 15:13:27,001 domogik-velbus INFO write packet
2013-09-17 15:13:27,009 domogik-velbus INFO write packet
2013-09-17 15:13:27,011 domogik-velbus INFO write packet
2013-09-17 15:13:27,018 domogik-velbus INFO write packet
2013-09-17 15:13:27,020 domogik-velbus INFO write packet
2013-09-17 15:13:27,028 domogik-velbus INFO write packet
2013-09-17 15:13:27,031 domogik-velbus INFO write packet
2013-09-17 15:13:27,043 domogik-velbus INFO write packet
2013-09-17 15:13:27,046 domogik-velbus INFO write packet
2013-09-17 15:13:27,048 domogik-velbus INFO write packet
2013-09-17 15:13:27,052 domogik-velbus INFO write packet
2013-09-17 15:13:27,066 domogik-velbus INFO write packet
2013-09-17 15:13:27,069 domogik-velbus INFO write packet
2013-09-17 15:13:27,071 domogik-velbus INFO write packet
2013-09-17 15:13:27,077 domogik-velbus INFO write packet
2013-09-17 15:13:27,085 domogik-velbus INFO write packet
2013-09-17 15:13:27,087 domogik-velbus INFO write packet
2013-09-17 15:13:27,090 domogik-velbus INFO write packet
2013-09-17 15:13:27,092 domogik-velbus INFO write packet
2013-09-17 15:13:27,104 domogik-velbus INFO write packet
2013-09-17 15:13:27,106 domogik-velbus INFO write packet
2013-09-17 15:13:27,115 domogik-velbus INFO write packet
2013-09-17 15:13:27,117 domogik-velbus INFO write packet
2013-09-17 15:13:27,119 domogik-velbus INFO write packet
2013-09-17 15:13:27,121 domogik-velbus INFO write packet
2013-09-17 15:13:27,146 domogik-velbus INFO write packet
2013-09-17 15:13:27,149 domogik-velbus INFO write packet
2013-09-17 15:13:27,151 domogik-velbus INFO write packet
2013-09-17 15:13:27,154 domogik-velbus INFO write packet
2013-09-17 15:13:27,156 domogik-velbus INFO write packet
2013-09-17 15:13:27,164 domogik-velbus INFO write packet
2013-09-17 15:13:27,166 domogik-velbus INFO write packet
2013-09-17 15:13:27,168 domogik-velbus INFO write packet
2013-09-17 15:13:27,171 domogik-velbus INFO write packet
2013-09-17 15:13:27,193 domogik-velbus INFO write packet
2013-09-17 15:13:27,196 domogik-velbus INFO write packet
2013-09-17 15:13:27,198 domogik-velbus INFO write packet
2013-09-17 15:13:27,200 domogik-velbus INFO write packet
2013-09-17 15:13:27,202 domogik-velbus INFO write packet
2013-09-17 15:13:27,222 domogik-velbus INFO write packet
2013-09-17 15:13:27,225 domogik-velbus INFO write packet
2013-09-17 15:13:27,228 domogik-velbus INFO write packet
2013-09-17 15:13:27,230 domogik-velbus INFO write packet
2013-09-17 15:13:27,233 domogik-velbus INFO Bus scan finished
2013-09-17 15:13:27,276 domogik-velbus INFO Start listening VELBUS
2013-09-17 15:13:27,280 domogik-velbus INFO Found node with address 0 and module_type VMB4RYNO
2013-09-17 15:13:27,799 domogik-velbus INFO Found node with address 32 and module_type VMB8PBU
2013-09-17 15:13:27,883 domogik-velbus INFO Found node with address 33 and module_type VMB8PBU
2013-09-17 15:13:27,952 domogik-velbus INFO Found node with address 34 and module_type VMB8PBU
2013-09-17 15:13:28,089 domogik-velbus INFO Found node with address 36 and module_type VMB8PBU
2013-09-17 15:13:28,159 domogik-velbus INFO Found node with address 37 and module_type VMB8PBU
2013-09-17 15:13:28,220 domogik-velbus INFO Found node with address 38 and module_type VMB8PBU
2013-09-17 15:13:28,288 domogik-velbus INFO Found node with address 39 and module_type VMB8PBU
2013-09-17 15:13:28,349 domogik-velbus INFO Found node with address 40 and module_type VMB8PBU
2013-09-17 15:13:28,962 domogik-velbus INFO Found node with address 49 and module_type VMBMPD
2013-09-17 15:13:28,983 domogik-velbus WARNING Received message with unknown type 176
2013-09-17 15:13:30,032 domogik-velbus ERROR Error while reading velbus device (disconnected ?) : Traceback (most recent call last):
File “/var/lib/domogik/domogik_packages/xpl/lib/velbus.py”, line 316, in listen
self.read()
File “/var/lib/domogik/domogik_packages/xpl/lib/velbus.py”, line 333, in read
self._parser(data[0:6+size])
File “/var/lib/domogik/domogik_packages/xpl/lib/velbus.py”, line 402, in _parser
methodcall( data )
File “/var/lib/domogik/domogik_packages/xpl/lib/velbus.py”, line 424, in _process_255
self._log.info(“Found node with address {0} and module_type {1}”.format(str(naddress), MODULE_TYPES[ntype]‘id’]))
KeyError: 34
2013-09-17 15:20:49,028 domogik-velbus INFO write packet[/code]
Best regards,
Hugo.
