Velbus fusebox and setup
hi
do you have any schema with velbus fuse protection, should it be between module commands and light bulb?
thanks
If you would connect eg. a VMB4RYLD voltage-out relay module or a VMBDMI-R dimmer module, you would connect the mains to a fuse, then go from the fuse to the N and L inputs of the Velbus module. So the fuse is upstream from the Velbus module.
A potential free relay would also switch after the fuse, of course. So again the fuse would be upstream from the Velbus module.
