VMB1TS temp. sensor
Is it possible to connect an external temp. sensor on the module?
If yes what kind of sensor I need?
If not can I put the inside sensor outside? What is the max. distance? I need a distance of 50 to 100 cm.
I wil use this in an aplication for control de temp. of heating tubes and Ineed a good contact with the pipes.
Adaptation of the VMB1TS as you describe it (i.e. bringing out the internal sensor) would be very difficult, even for an experienced electronics expert. Not recommended.
The Velbus team has started work on an analogous in/out module which will permit easy connection of, amongst others, PT100 temperature sensors for instance. This module will probably not be available before beginning of next year however.
2 years ago, you say that The Velbus team has started work on an analogous in/out module which will permit easy connection of, amongst others, PT100 temperature sensors for instance. This module will probably not be available before beginning of next year however.
What about that?
