Water counter - 1 pulse per 100L
The water distribution company installed in my house a water counter generating 1 pulse every 100L (Cycle counter KLF 100).
I don’t see how to configure this in the VMB7IN. The minimum is 1 pulse per 1L… and then more than 1 pulse per L… but not the other way around…
Is it possible?
Thank you
1 pulse per 100 litre seems like an extremely low rate.
Could you double check that it isn’t 1 pulse per 100ml, which is still a very low resolution.
For example, I have a very cheap inflow pulse generator which creates 1 pulse per 2.5ml.
Cheers,
