When you use your Velbus-server are you able to use it to scan the complete bus?
Because when I use it, connect VelbusLink8 to it and do a full scan I only get the answer from the first module on the bus.
When I use VelbusLink6 in servermode I get answers for all modules.
Any pointers to start troubleshooting?
Edit 1:
I fiddled with your code a bit and my send/receive test app works if I set the receive buffer of your Server app to 14 bytes (lenght of a velbus packet).
Velbuslink8 however only get replies from about every other 5 modules so i’m missing a lot… (Still better than in the beginning, I only got the answwer from the first module)
The next thing I’ll try is sending the packets to the connected clients with 60ms delays, like Velleman does to not overload the bus.
I’ll keep you guys posted.
Edit 2: Velleman: As mentioned before my scantool works as expected with a receive buffer on the server side of 14 bytes.
A full scan with VelbusLink8 however makes the server throw Out of range exceptions in the bus.Send(packet) call.
Error: base {System.ArgumentException} = {“Specified argument was out of the range of valid values.\r\nParameter name: Packet does not contain a command byte.”}
Occurs when you try to set the Command property of the Packet class when the number of databytes has not been set yet.
About troubleshooting your problem, be sure to check the following:
A delay of 60ms must be present between each packet sent to the Velbus interface modules
a) VelbusLink 8 does not add this delay for a TCP/IP connection, it expects the server to add this delay.
b) VelbusLink 6 in server mode adds this delay, since it is considered the server
VelbusLink 8 with a TCP/IP connection will send its scan packets as fast as it can (see 1a); the server buffers the packets, adds a delay, and sends them out; thus VelbusLink 8 may have stopped scanning, even though the server is still busy sending out the packets
The Send() procedure of the Serialbus Class does implement the 60ms delay I presume, the SendBlocking does not as I understand. So this should not be a problem.
As you can see VelBusSend procedure uses a Byte array to generate the VelBus packet using rawpacket/Pack.
I’ll try to skip the conversion from/to a Byte array and see if this fixes things.
private void OnDataReceived(IAsyncResult asyn)
SocketPacket socketData = (SocketPacket)asyn.AsyncState ;
try
int iRx = 0 ;
// Complete the BeginReceive() asynchronous call by EndReceive() method
// which will return the number of characters written to the stream
// by the client
iRx = socketData.m_currentSocket.EndReceive(asyn);
//check existence of client:
if((socketData.m_currentSocket.Poll(1, SelectMode.SelectRead) && socketData.m_currentSocket.Available == 0))
string msg = "Client #" + socketData.m_clientNumber + " disconnected.";
Console.WriteLine(msg);
m_workerSocketList[socketData.m_clientNumber - 1] = null;
} else {
//Passing the packet trough to the VelBus-code
pp.Feed(socketData.dataBuffer, iRx);
Packet packet = pp.Next();
while (packet != null) // did we succeed in parsing a packet?
ReceivedPacketArgs ra = new ReceivedPacketArgs(packet);
VelBusSend(ra);
packet = pp.Next();
// Continue the waiting for data on the Socket
WaitForData( socketData.m_currentSocket, socketData.m_clientNumber );
catch (ObjectDisposedException )
System.Diagnostics.Debugger.Log(0,"1","\nOnDataReceived: Socket has been closed\n");
catch(SocketException se)
Console.WriteLine(se.Message );
I first had that problem to with mt version of the server (linux). I solved this with a big receiving buffer (to have as much as data in at once) and than cut the bulk data back into the right packets (you can count the bytes because there’s a number of bytes in the packet) with a delay in between.
In the other direction (interface -> network) I send as soon there’s data available.
I 'd never problems since the change, even a full backup of the complete system works perfectly.
Yeah, I should have mentioned that I tweaked the rest of the code a bit to. I’m planning to make it into a windows service controled by a form application to set the hostname and port, I’ll make it available on the forum as soon it is finished.
At the moment I use a 1024 byte buffer. The packets are carved out of the buffer by the Velbus PacketParser, nothing to code there.
Edit:
Upped the receive buffer to 2k, a buffer of 1k would overflow with 2 clients scanning the bus at the same time crashing the server.
Tried different sizes, 8k would crash on the first packet received (what’s the max size the PacketParser can handle by the way?) 2k seems rock solid.
Brilliant!
Have bombed it with packets, no problem!
Would be nice if it could run as a service, not under a user account…
And would be even nicer if it remembered te COM and TCP ports.
i’ve use your velbusconnector usercontrol but i can’t receive any reply from velbus. Seems that the ReceivedPacketArgs event isn’t raised. Can you look into that bit of code?
If you want to use my control on a forms application and use the PacketReceived in your code behind, you’ll have to add an event handler like this:
public Form1()
InitializeComponent();
velbusConnector1.PacketReceived += new VBConnector.PacketReceivedHandler(velbusConnector1_PacketReceived);
I myself use usercontrols with a VelbusConnector property for every Velbus function and I handle the PacketReceived event in these controls so I don’t need the event handler in the main form.
