Connection to Home Assistant
the working connection did not work
it looks like it connected for a sec en loaded some parts but whas not able to keep connected
today i am going to the store to look for a usb a to usb a cable and try to connect the new ha via usb to the signum
my first ha i just enterd my signum nr and the ip adres
tryd multiple times nog it does not seem to work
only thing that i have in my mind is that both the ha unit wont the same adres and that may be one of the faults
but for the life of me i am not an it guy so would not know how to change that
May I suggest that you look at what Velbuslink uses to connect and confirm that it’s stable first.
I appreciate you’re not an IT expert, so please keep it simple to start with.
We need to identify where the issue is, rather than change connection methods.
If signum works and Velbuslink works over your LAN, then the problem is within the new HA box.
my original very stable
that why i thing that the new one is trying to fight over the adres they are both trying to be local 8123
i just unplugd the signum and now the new ha is stable
that more or less confurms my thougt that they are fighting for the same gate
any idea how to change that
I’m a little confused.
Are you suggesting that your new HA device is clashing with the IP address of your Signum?
The Ports / Gates on each machine should never conflict, because they reside on different machines.
indeed stupid of me to think that i whas confusing gate with ip adres
like i say not an it expert
but for the life of me i can not get the velbus instaled again
alway the same error ( unkown error )
everything else work flawless on the nog HA exept velbus
al problem are solved now thats to the great work of maikel punie ( cereal2nd ) on git hub
there where things wrong with the settings in velbus and problem on the HA green
thanks again maikel to look into in and settings op
Excellent news.
Are you both happy to add a link to your GitHub communications, for others to read that might have a similar issue?
i contacted him via mail true github
not something i would normal do
he whas kind enough to do a remote view into my computer en reinstalled some stuff en modified some code
honnest seen what he did not in a milion years i would have found the problem
it took him the better part of an hour mey b little more to find and fix the error
this whas a part of the problem he screenshot
still need to buy him some coffees via the site
He is indeed a true magician.
