JayS
1
Hi, I’m back, this time with a behaviour I don’t understand:
- I have the same set of instructions (commands) copied to 2 distinct GPOD
- when operating the buttons on the GPOD, the commands don’t work and no feedback led’s react (on both of the GPOD)
- when simulating the very same instruction on Velbuslink (button operate) it works and feedback leds on the GPOD respond correctly
What can be causing this?
Thanks for your support.
MDAR
2
Can you do a complete re-write of the affected / involved modules, then try again?
JayS
3
Thanks for the prompt reply. By complete re-write you mean clear involved modules and redo all commands on them, or just those not responding? Thanks
MDAR
4
Oh no, nothing that drastic.
Just click on Sync as normal, just select the modules that you know are involved in the issue you are talking about.
Un-Tick the “only write changes” button
then click on Write.
This will cause all the selected modules to have their configuration wiped and re-written as per your project.
I have seen that sometimes, after lots of small amendments, some modules get a bit lost, so by performing a “Full write” you clear any strange issues.
If… the issue persists after this, then you know to go digging deeper.
JayS
5
Got it MDAR, thanks for your time. I’ll let you know how it went.
