Load large project .vlp
Open one node (a VMBDMI in my case) halfway down the Project Navigation
Quick connect
Scan
Scan stops halfway through. Everything locks up. Then eventually a “Failed to respond” message from Windows inviting me to close the app.
This does not happen if I make sure there are no expanded nodes when I connect.
Apart from that 10.9.3 is a big improvement. Status update immediately on expansion of a node makes it feel much more responsive. And I have not seen the ghost floating shadow boxes with this one.
And you too! Good to see you here.
I am pleased to be able to report that all my long CAT5 cable runs that I was worried about have worked just fine.
Currently connecting via Velserv (on a PiZero), just using it as a WiFi gateway.
All my main velbus nodes are on rails in the loft so Velserv makes it a lot easier to be able to walk around downstairs with a laptop to try things out and see the results.
