Pressing the “slow” button inhibits the medium/high relays and thus makes the ventilation fall back to slow speed. Pressing the “medium” or “high” button cancels this inhibition (through an intermediary virtual relay) and switches the medium resp. high speed on. Pressing “slow” again, falls back to slow speed by inhibiting again the two higher speeds.
Position 1 = Slow (Always ON)
Position 2 = Medium (toggled VMB1BLS Up)
Position 3 = High (toggled VMB1BLS Down)
Anyway, now i can integrate the ventilation control on top of the original RF control.
Al right, time to bring this to the next level and go for Ventilation Control 2.0
So the idea is to have the ventilation to position high when the light in the bathroom is on for 3 minutes, then goes to position slow when light has been switched off after 5 minutes.
More or less a copy of the FAQ solution for -> toilet - ventilator delayed on\delayed off.
But due the fact there is no relay for the ventilator but a blind control I’m missing action 19.delayed off when relais on. Here i would need a workaround… any ideas?
Any suggestion that would put me on track again is appreciated
I’ve categorised my velbus installation under hobbies now… so I’m home playing with this installation, which means happy wife
Hmm yes, i could place another VR in between. Because this one can ‘accept’ a 19.switch off if relay on command and ‘send’ an 65.inhibit. Same function as the slow button.
So it must be like this then
I will try antoher option, because honestly i don’t get the Inhibit stuff either (among a lot of other functions), so following the learning by doing path.
(also there is a mistake in previous overview, initiating f69 from a virtual relais is not possible)
Sorry for the delay in replying, I’ve been struck down with this stupid winter cold that’s going around.
With regard to your timed ventilation control, AFTER the light has been switched off…
I’ve tried all kinds of combinations of commands, but the “Delay Off” effect that is so easy to achieve with a relay channel just doesn’t seem possible with a blind controller.
Putting a pair of virtual relay channels between the up and down actions of the blind controller is the only option I keep coming back to, but that just makes the logic really messy and I don’t have a way of testing it right now. (I sold my spare blind controller last month)
When I get another, I’ll throw something together and see if I can come up with a solution.
