Alarms on channels 9 to 32 on the VMB8IN-20
Is it possible to enable and use the alarms on channels 9 to 32 on the VMB8IN-20.
Thanks in advace
You need to assign the subaddresses to the module to use them. There’s a known bug in VelbusLink they are displayed even if they don’t have an address assigned.
I’m facing the same issue… I can’t assign sub-addresses to the alarms.
The main address is 3 (inputs 1-8) but for the other channels won’t accept an address.
FIXED - an update to the latest build fixed this issue
