On the backdoor i have a read-switch that will be activated when the door opens. I will do the following:
When the “alles uit” is activated ( AND it is sunset – can be an additional candition) then “alles aan” should be activated.
I’ts a magnetic read-switch fixed on the back-door and electrically connected to an input from a VMB7IN pin 2, this pin is configured as a N/C (normal closed).
What is will do:
When i go to bed (after sunset) i push on one of the buttons in the bedroom for 3 seconds, at that moment i generate an “alles uit” macro. So all the lights on the level-0 (gelijkvloers) will be off. When someone (a burglar) will now be enter via the back-door all lights in the whole house should be go on.
So the conditions for this action should be: (sunset – not nessesary) at least, Button “bedroom” pushed for 3 seconds (= “Alles uit” macro).
I can indeed add the “enable” function to the VMB7IN port 2 when the “alles aan” button is pushed, but i don’t find the method to disable this function automatically by sunrise even when i don’t push any button.
I can “disable” it when i push a button but is it possible to disable it without touching a button?
can you send me a screenshot of what you mean, (or export a small example and post it here) i’ts not clear to me how to activate a program without pushing a button.
This image is of the program steps tab in the configuration panel of a VMB7IN.
You’ll see that I’ve set Channel 6 to Lock (Disable) an hour after Sunrise.
(I think the confusion was that I was calling it “Disable”, rather than “Lock”, which is because in other modules this feature is referred to as “Enable” and “Disable”)
To double check that the correct program group is active at any time, you can simply select any channel of the module you want to check and right click to see the “operate” option.
This will produce a pop-up like this, where you can select the active program group for the whole module.
You’ll also be able to see if the channel in question is currently locked and that it’s program steps will be used.
Does that make it clearer?
A picture paints a thousand words
Good luck
Which reminds me…
Some other confusion might be that sometimes “Program Group 1” is referred to as “Winter”, “Program Group 2” as “Summer” and “Program group 3” as “Holiday”
