An Irrigation System - in Velbus
Hey everyone,
This is my script for a custom sprinkler system for Velbus/OpenHab… in short what it will do in a full sequence:
Open Valve 1 (channel 1)
Start Motor (channel 4)
Wait x seconds
Open Valve 2 (channel 2)
Close Valve 1 (channel 1) - valve 2 is opened first to avoid pressure build while pump is running
etc…
close motor
wait a few seconds
close last valve (3 channel 3) (valve is closed after the motor to avoid pressure build in the system)
There is also a manual start procedure
Activating a single valve - will trigger the motor to run for x amount of seconds
Activating valve 1 and 2 (within 2 seconds) will initiate a full sequence run
On system startup - all valves and motor will be shutdown
On regular checks - all valves and motor are checked and if running (without permission) will be shutdown
sprinkers-new.log (8.5 KB)
It’s so a good project. We had an irrigation system in our last home in Hackney. It was a Gardena system, their products are the best I’ve come across. Pricey, but reliable, and there were all types/sizes of sprinklers, drips, pipes, joints, etc. Brilliant. And there was a battery-operated pump that you could program for frequency and length of watering time etc.
