Any good solutions for a sounder/alarm/notification?
I have arranged for our external post-box to be able to generate velbus events.
(433MHz radio TX from ebay in the post-box, and a little home-made arduino radio module with 8 outputs directly connected to a VMB8PBU connected to my velbus in the loft). I thought 8 radio channels from arbitrary things that can be set to make velbus events would be useful. There are also some very cheap battery operated PIR-detector with 433MHz transmitter that I think should work well with this.
So… now what to do with this inside the house? I could just have the arduino send another radio signal to an off-the-shelf cheap doorbell module but it would be nice to use the velbus.
I am thinking a simple “Bing Bong” sound, or something like that, inside the house might be good.
Maybe I should just make something but I thought I should check first… Is there an already existing “Box” that can respond to velbus or radio triggers and make different sounds.
Excellent question.
One that I faced in my own home.
I have a long thin house and needed multiple door bells / Sounders. (As we never find hear one from everywhere.)
When I pulled in the Velbus cable, I also pulled in a very simple 2-pair cable, not knowing what I’d do with it.
As it happens, I hooked up one end to a Velbus relay and switched 12V to it.
Wherever I wanted a doorbell / sounder, I grabbed the Velbus Gnd and the 12V switched feed.
I was very lucky and found some tiny fully programmable Sounders, that can store up to 30sec of audio.
They work incredibly well, but they’ve been discontinued :cry:
If they ever fail, I’ll go looking for another type or have to resort to any 12V sounder or doorbell that I can find / like.
Is there a Velbus compatible doorbell?
No, but I have been asking for a VMBOEM module for years and years.
The best we have now is the VMB1RYS
https://www.velleman.eu/products/view/?id=452920
1 relay & 1 input
A brilliant like box
There is a tiny hint of a rumour…
That the new VMB6PB-20 might evolve into something rather special… :wink:
I’ve just found this for £10
Not a “music player” like the ones I have (for the same price) but could play a sequence?
Or this open PCB, which would need a speaker and amp
https://www.amazon.co.uk/Playback-Trigger-Amplifier-Control-Compatible/dp/B07YDNP5B9
This is closer…
But still an open PCB, at least it comes with a small speaker
https://www.amazon.co.uk/Talking-Products-Module-Battery-Crafts/dp/B07CPX9N8N
