I use VMB2BL to control my 11 blinds. As it is Bubendorff MG motor, there is 4 wires :
Permanent Phase
Neutral
UP
DOWN
however, these motors could receive CPL signals and it seems that it cost power (around 18W when sleeping / doing nothing) : that way, my house use around 200W for nothing
Have anybody the same problem ? is it possible to put permanent phase on a VMB4RY (what is the power consumption when blind become active) ?
Permanent Phase
Neutral
UP
DOWN
Hi VEL324 (a first name would be more friendly butâŠ)
I need the consumption of Bubendorff motor in sleep mode and active mode, however, not for the same Velbus module :
VMB2BL controls UP/Down wire â active mode
VMB4RY would controls sleep mode (around 18W for what I can imagineâŠ) and maybe an other consumption on permanent phase wire (Bubendorff MG motors have 4 wires : UP, Down, Neutral and permanent phase)
So in this case, Velbus is OK but Bubendorff donât answer to my question : what is the cunsumption on the permanent phase (sleep and active mode).
I take little time to make this draw⊠Velbus, please me if you can contact Bubendorff directly (maybe your society could have more power than a simple user) because it use 200W permanently !!!
Idea is to start VMB4RY in same time that VMB2BL but keep VMB4RY active for a timer of 5mn (for example).
Have you tried measuring the current yourself, seems to be the fastest way to know the power used.
Have you tried running the motors without the permanent phase?
You could use two 2NO relais per blind (like the vynckier CTX+R1620230A for example) and switch the up/down and the permanent phase (about 25⏠a pop, so will be over 550⏠for you complete installation)
Have you tried measuring the current yourself, seems to be the fastest way to know the power used.[/quote]
Not easy to do because directly connected on disjoncteur : maybe put the multimeter in (10A mode)
Of course : nothing happens
I used Schneider Electric parts (Ah yes, Grenoble is the born place of Merlin-Gerin wich become Schneider Electric ) relais for controlled electrical plug⊠but want to avoid 550⏠if not needed
canât you ude the vmb4ry in momentairy mode and than be activated by a blind up/down command. I thought a relais module could control another module (commando side seen) instead of using an input switch module.
Measuring the current would be easy with a clamp meter if you have one available.
You could use a vmb4ry(ld/no) channel per blind and add the relais command to your up/down buttons (make sure to use a timer), but youâll need 3 modules at âŹ179 a pop wich will cost you âŹ537. So it wouldnât be much cheaper. Plus, the vmb4ry draws a standby current (not much but a relais doesnât)
Have you tried contacting the manufacturer of your motors? Maybe they have a solution?
Yes itâs me in each case (the day I works as a nice employee for a respectable society⊠but the night, Iâve others suspicious activities⊠but my name isnât Neo or Anderson )
ouf Iâve not write anything bad on Velbus in others forums
So I think this week-end would be a test week : Bubendorff seems to be deaf
Bubendorff still deaf to my requests but my multimeter is my best friend (after Google search of course)
So I used the intensity mode (10A) and insert the multimeter between 230V and my bigger blind (2,80 x 2,10 meter).
Bubendorff MG Motor consumption : Standby mode : 120mA (~27,6 VA)
Active mode : 840mA (~193,2 VA)
Hope this will help some guys 8)
Of course, no thanks to Bubendorff France (maybe theyâre better in other countries)
