Bug in the software (Velbuslink v.5.6.7.996)?
I am using velbuslink v.5.6.7.996. All devices on the bus are correctly detected. So is a VMB1RY correctly detected. But when i select this module and click on configure, i get (after a seamingly correct loading) the following error: “Could not find memory definition file …path…\VMB1RY_0633.XML”. The module seems to be functioning correctly.
Extract the file vmb14Y_0633.zip to the Maps/ folder of your VelbusLink installation.
For a default installation this should create the following file:
C:\Program Files\Velleman\VelbusLink\Maps\vmb1RY_0633.xml
This should solve the missing file problem
Enjoy!
