Can´t find file VMB1TS_0009.xml
I have a temperature controller and when I try to configure the Velbus Temperature Sensor appears the following mensage:
Could not find memory definition fileC-.ProgramFiles\Velleman\VelbusLink\Maps\VMB1TS_0009.xml
Wherefrom is it possible extract the file? Can someone pass it to me?
Thank you
Ibon
i had the same problem
so i just copy the file C:\Programs\Velleman\VelbusLink\Maps\vmb1TS_0823.xml to vmb1TS_0009.xml and wokrs fine.
th
Cat
Indeed, this is a good solution
Thank you. It works.
I think I have the same problem with TVMB1TC, Do you know if it needs a file too?
ibon
[quote=“catuser”]Hi
th
Cat[/quote]
hi,
that problem is a little diferent.
there is no file to copy.
Maybe on the new version of velbuslnk but I don´t know when is out.
cat
