I kindly ask you to input modules VMB8PBU connect and two inputs as “ch1 bright twilight” + AND / OR + “ch2 clock timer”, basically have two confirmations to activate a command. ???
Then I wanted to ask you can copy the commands dedicated to one input to another,
not to make manual insertion every time ???
If your question is: “In Velbuslink, can I copy the actions connected to one button, to another button?”, the answer is: yes.
Ctrl-click on the first button and drag onto the second button.
[quote=“VEL345”]If your question is: “In Velbuslink, can I copy the actions connected to one button, to another button?”, the answer is: yes.
Ctrl-click on the first button and drag onto the second button.[/quote]
my question was whether it is possible that ch1 output is active only when both inputs ch1 and ch2 are pressed and not when one least one of the two is not pressed
