Daikin
Hallo
Iemand die weet of Velbus kan werken met Daikin klimaatregeling?
Mvg
If you have the daughter board for the (commercial) Daikin units, you can link the in & out connections very easily.
I’m happy to advise if you have the exact model numbers for the Daikin unit you want to use.
although not Daikin (they also do KNX/BACNET - which you could access using an extension such as OpenHab) - I have split duct units from O’General (Fujitsu) - they have an accessory that translates the native bus system to standard Thermostat outputs (Y/W/G) - Daikin may have the same
see also: Heating and Cooling Guide (wordpress.com)
