start: output=off
=> push button pressed: output=on
=> push button pressed for longer time: output=on, after 5 seconds dim out
set dimmer operation mode to Slow-off dimmer
set dimmer time setting to 5s
start: output=on
=> push button pressed: output=off
=> push button pressed for longer time: no action
set dimmer operation to dimmer
set dimmer time setting to ON-OFF
use for configuration velbuslink 8.2
You need 1 VMBDM1, 1 VMB8PB, 1 VMBRS or 1 VMBUSB,2 pushbuttons, powersupply and velbuslink 8.2(download for free at velbus)
VMBDM1 = dimmer
VMB8PB = 8 pushbuttons
VMBUSB = vellbus to usb interface
VMBRS = ???
is this possible with the same dimmer?
because i don’t find a place (in velbuslink) to configure the dimmer operation, so i guess its something on the module …
in velbuslink 8.2 select the module you want to configure, goto actions, select add. next screen topline select interface(vmb8pb) and channel. second line select module for action(vmb1dm). next select action.
first case select action n° 4 (set operationmode to 6 or E and time setting to 1 on dimmermodule)
