Dimmers & 6 channel input module?
Hi, Couple of questions if I can.
  1. Is there any plans for a higher wattage dimmer module? Most manufactures are up around the 700watt mark & 300watt seemed a little low.
  2. Is there a more detailed spec sheet on the 6 channel input module. I wanted to use this to send 6 different SMS messages via another unit to report on activation of certain equipment.
Many thanks.
Chris.
No plans for a high power dimmer at this time.
You can download the extended manual of the six channel input module here:
velleman.be/downloads/0/velbus/manuals/long_version/vmb6in_uk.pdf
