Would that require a full Velbus deployment of meters? or is this an integration with Home Assistant ? I already have the Home Assistant fully setup with my inverter + Smart meter - Is it possible to send that information to the Velbus displays? if so … how ?
The concept is that there is a kit available for people without a Velbus system, so they can get a very easy visual representation of their energy usage.
The kit is fully prepared and ready to use, with Velbuslink having a wizard to adjust thresholds and edge colours etc.
For those of us that had the foresight to invest in Velbus, we only need the extra modules to achieve the same result.
Assuming you have edge lit panels in your system, you need only a bidirectional energy meter (FIN7M.38.8.400.0112) and two spare pulse inputs on a VMB7IN.
With the latest version of Velbuslink, you can get your current usage displayed and affect the edge light colours to give an “at a glance” status report.
Hello, I’ve implemented this setup, but I cannot see the trick to change the colors on the screen? I see that the VM7IN has a threshold for the alarm, but how can I select the colors based on the alarm? I know you can forcely set a color on the display, but how can I find the trigger for it?
There is indeed a threshold with an alarm inside the configuration, which I’ve setup, but I cannot find these warning in the Velbus system to trigger for example a red light?
