I have a simple configuration, the VMB8PB 8 push button module connected to the VMB1USB and no other modules. I started with one or two momentary contact switches but in order for me to get it to work, I had to remove the two “Terminators” o both modules. When I added a third PB I am using for a water level control, the sensor (reed switch) is Normally Open. When the water level drops it closes and should activate the PB, however when I started the application, the reed switch was Closed (low water) and I get the Erroneous State error.
- is it normal for this to occur if the switch (PB) is closed at start up, vs starting in the Open state?
- when I tried adding the terminator to either module, it would not work (uisng Velbus link 6 to watch the state
- on the vellmanusa.com web site I see that the VMB1USB states the product has be removed from the range of products. What is the replacment?
Thanks
Ray
