Error message when configuring VMB8IR
I just upgraded Velbuslink to the latest version 9.32
When trying to configure the VMB8IR module (F6) I get the following error pop up: A component named btnOK already exists.
I removed the VMB8IR and configured it from scratch with the same error.
I also updated the VMB8IR firmware to the latest version (1112) with the same error.
I installed velbuslink 8 and everything worked correctly again.
Regards,
Rudy
You are correct, this seems to be a bug in version 9. We will try to get it fixed as soon as possible.
