Experiences wanted with 230V Led lights for VMBDMI?
I’m using a VMBDMI with 4 incandescent E27 bulbs of 60W, like these:
I want to replace them with 4 LED bulbs. Something like this:
These bulbs are not cheap and I can’t return them to the shop once I buy them, so does anybody has experience with similar bulbs that do dim well with a VMBDMI?
I know that a lot of these lights do not dim very well with this dimmer, so I hope to hear experiences from actual users…
Also, what’s the experience with low light: does it still dim without flickering and giving a warm glow?
thanks!
Hello Gert :wink:
Have you done a search on this forum for mains replacement LED?
I remember someone else asking the same question.
forum.velleman.eu/search.php?keywords=Mains+replacement+led&terms=all&author=&sc=1&sf=all&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
My own experience hasn’t been great, I’ve found only 1 dimmerable LED similar to the one you’ve pictured, which happened to be from that will known Swedish furniture vendor :wink:
While it did Dim acceptably with the VMBDMI, it does snap to about 25% from nothing, and if you’re after a faint glimmer, then you’d be better off with incandescent lamps :wink:
Unless you swap to pure low voltage dimming and low voltage fixtures.
I’ve retagged a load of example videos on YouTube with “Velbus DMI Dimmer Vs. test lamps”:
youtube.com/playlist?list=PLCHw8A4D87YCagWde5wD9CmFVrO_IcLGJ
If you do find something that works well, please let us all know :slight_smile:
Anyone else know of any lamps that work well?
Cheers,
Hello.
As a follow on from this thread, I’ve created some truly dull videos which show the VMBDMI-R or VMBDMI connected to various Mains Replacement GU10 LED lamps that I can buy in the UK.
Velbus DMI Dimmers Vs. test lamps: youtube.com/playlist?list=PLCHw8A4D87YCagWde5wD9CmFVrO_IcLGJ
Thankfully they are only about 2 minutes each, but you will get a good idea of which lamps I’ve found that work (or don’t work) with the DMI / DMI-R modules.
Cheers,
