When Velbuslink 7.1 is asking then VMB6IN module input names using the command: EF3F (databyte1: H’EF’: COMMAND_INPUT_NAME_REQUEST, databyte2: B’00111111’), the module is transmitting the thirth part of the name not correct. It should transmit 6 databytes (databyte1: H’F2’: COMMAND_INPUT_NAME_PART3, databyte2: input bit number, databyte3,4,5: last 3 characters of the input name, databyte6: H’FF’). But it transmits a faulty packet with 8 databytes: databyte6,7,8 are the contents of the memory table following the name of the input channel).
When asking the module input names one-by-one (EF01 / EF02 / EF04 / EF08 / EF10 / EF20 in stead of EF3F) (as Velbuslink version 6 does), there are no errors.
Greets
