I’m unable to upgrade the firmware of the VMBKP from VelbusLink 11.0.2.2.
The upgrade process stuck at 0%.
velbuslink_15-10-2023.log (576 Bytes)
I’ll try with mine and see what happens
Still the same problem with the version 11.0.3.0 of VelbusLink.
I see your keypad is on V1927, that’s quite old now.
I just opened VelbusLink 11.3.0 to discover that my Keypad was already on Firmware version 2047 and there isn’t anything newer.
Unfortunately, I can’t remember when it got moved to that version, so I must assume it was a painless process.
I’ll try to find a change log so you can see what is different.
https://cdn.velleman.eu/downloads/velbus/velbuslink/changelog_velbuslink_en.html
Last mention of VMBKP
Thanks for taking a look at your installation.
I installed it last week.
I didn’t have the possibility to update it sooner. ![]()
We’ll have a look if we can reproduce that here.
Still the same problem with the version 11.0.4.0 of VelbusLink.
Still the same problem with the version 11.0.6.0 of VelbusLink.
Is there any way you can bring another cable to your keypad?
It has been fixed in VelbusLink 11.0.7.
Thanks ! Module upgraded.
