Hi, on an install with several GPOD-2, after a power cut, some of them are freezed, don’t operate, can be re-established after taking power down again. It doesn’t happen always with the same gpod’s. Is there a permanent solution to this issue? Did I miss something on the gpod’s configuration? Thanks
Can you report this to Velbus directly please, with as much information as possible.
info@velbus.eu
When you send the mail to our support mail, attach the VelbusLink project file and the module addresses of the affected modules if possible. That perhaps will help us to reproduce the problem.
Thanks for the support, I’ll prepare info to be sent.
