With this addon you can simply connect your hassio device to the serial bus, let hassio connect to the local tcp/ip port and also provide connectivity for velbuslink.
This addon was requested multiple time, and now its finished and useable
hi @cereal
This was exactly what I needed. Got my setup up and running again in HAOS, thanks to your addon! @MDAR : thanks for pointing this out. Installation is working again, and far more easy to manage!
Dear,
Thank you for your Addon.
I have installed your Addon en selected the Velbus USB.
I disable in the Velbus integration the USB en ADD tcp connection.
Afther this is see not all my devices. On the USB i see 23 en on TCP 11. and on the entity i see on the usb 400 and on tcp 100. Can you explain what id o wrong? On the Velbus link i see not al my device too
This Addon is a USB to TCP gateway, much as VelServ and Velbus-tcp, however this one sits within the HomeAssistant environment.
Whereas the Velbus Integration within HomeAssistant is where the magic happens, converting Velbus data packets (passed directly from the USB connection or the VelbusD TCP gateway) to a format that HA understands.
