HIS - server disconnect message through VelbusLink
Hi, I can connect to HIS through HomeCenter or dialing the IP address in a browser, within the LAN, When trying to connect using Velbuslink, I get a “server disconnect” message from the HIS - what’s wrong? Thanks
Make sure you choose the “Connect to HomeCenter Server (TCP/IP)” option in the connection dialog.
Also verify the port (default 8445) and the authentication crendentials.
Kind regards
Thanks for the prompt reply. My mistake, I was using port 8443!!. Solved
Thanks for the support
