this is all you need currently, all other info is auto-detected …
Dear Cereal,
Thank you for your answer.
However, in 0.77 it did not work, updating to 0.78 solved it.
So there was a bug
Thanks again!
0.82 will have velbus thermostat support
next up are the blinds, but this is a bit more tricky to implement as i don’t own these modules …
so there was a bug in 0.77, need to check this out then
cool so version 0.82 will have the thermostat function? Been waiting for ages for that
thanks man
hmm, they delayed it to 0.83 …
so the just release 0.82 does not have it
dear I have tried several times to get the Home Assistant working, but I can not, I currently have version 0.85.0
I do the settings but at this moment I see in the log that a scan is done of the bus, but I do not see any Sensors / switch … appear in HA, my setting is currently:
velbus:
port: ‘/ dev / ttyACM0’
What do I have to do to get this working?
greetings Joram
Just a thought, is your Velbus USB device definitely assigned /dev/ttyACM0 ?
For example, do you have anything else plugged in that might be assigned ttyACM0?
You could check if there is a symlink in /dev/serial/by-id/ that is named as the Vellerman / Velbus interface and points to the assigned ttyACM ?
the connection between ha works but nothing appears in ha. I have to put more in the config file outside the usb connection
I was under the impression that the latest version now automatically detects your Velbus modules.
https://forumtest.velbus.eu/t/home-assistant/14666/11
So (with the risk of sounds very dull), as you absolutely sure that ttyACM0 is your Velbus adapter?
Or…
Do you need to trigger a scan?
HA log : core-ssh:~# hassio homeassistant logs
2019-01-13 12:21:38 INFO (Thread-2) [velbus] Processing message b’\x0f\xfbg\x08\xbe"\x02+\x02I\x06A\xe8\x04’
2019-01-13 12:21:38 INFO (Thread-2) [velbus] New message: {“name”: “CounterStatusMessage”, “priority”: 251, “address”: 103, “rtr”: false, “pulses”: 800, “counter”: 36373065, “kwh”: 0, “delay”: 1601, “watt”: 0, “channel”: 3}
2019-01-13 12:21:39 INFO (Thread-2) [velbus] Processing message b’\x0f\xfb\x1e\x08\xed\xaa\x003\x00\x00\xc0\n<\x04’
2019-01-13 12:21:39 WARNING (Thread-2) [velbus] received unrecognized command 237
2019-01-13 12:21:40 INFO (Thread-2) [velbus] Processing message b’\x0f\xfb\xfe\x07\xa9\x02y\x11\xad\x00\x00\x0f\x04’
2019-01-13 12:21:40 WARNING (Thread-2) [velbus] received unrecognized command 169
2019-01-13 12:21:40 INFO (Thread-2) [velbus] Processing message b’\x0f\xfb\xfe\x08\xac\x02\x00 63.3X\x04’
2019-01-13 12:21:40 WARNING (Thread-2) [velbus] received unrecognized command 172
2019-01-13 12:21:40 INFO (Thread-2) [velbus] Processing message b’\x0f\xfb\xfe\x08\xac\x02\x05 mm/h\xac\x04’
2019-01-13 12:21:40 INFO (Thread-2) [velbus] Processing message b’\x0f\xfb\xfe\x04\xac\x02\n\x00<\x04’
2019-01-13 12:21:40 INFO (Thread-2) [velbus] Processing message b’\x0f\xfb\xfe\x08\xac\x04\x00 452e\x04’
2019-01-13 12:21:40 INFO (Thread-2) [velbus] Processing message b’\x0f\xfb\xfe\x08\xac\x04\x055 lux\x8d\x04’
2019-01-13 12:21:40 INFO (Thread-2) [velbus] Processing message b’\x0f\xfb\xfe\x04\xac\x04\n\x00:\x04’
2019-01-13 12:21:40 INFO (Thread-2) [velbus] Processing message b’\x0f\xfbS\x08\xedA\x02\xa7\x00\x00\xc0\n\xfa\x04’
2019-01-13 12:21:40 WARNING (Thread-2) [velbus] received unrecognized command 237
2019-01-13 12:21:42 INFO (Thread-2) [velbus] Processing message b’\x0f\xfb\x0e\x08\xedA\x02\xb9\x00\x00\x00\n\xed\x04’
2019-01-13 12:21:42 WARNING (Thread-2) [velbus] received unrecognized command 237
2019-01-13 12:21:43 INFO (Thread-2) [velbus] Processing message b’\x0f\xfb\x16\x07\xe6\x12\xc0\x03\x1a\xe0\xc4\x04' 2019-01-13 12:21:43 INFO (Thread-2) [velbus] New message: {"name": "SensorTemperatureMessage", "priority": 251, "address": 22, "rtr": false, "cur": 9.375, "min": 1.6875, "max": 13.4375} 2019-01-13 12:21:43 INFO (Thread-2) [velbus] Processing message b'\x0f\xfbg\x03\xbd\x01\x00\xce\x04' 2019-01-13 12:21:43 INFO (Thread-2) [velbus] New message: {"name": "CounterStatusRequestMessage", "priority": 251, "address": 103, "rtr": false} 2019-01-13 12:21:43 INFO (Thread-2) [velbus] Processing message b'\x0f\xfbg\x08\xbe \x02O.\x06B\x82\x04’
2019-01-13 12:21:43 INFO (Thread-2) [velbus] New message: {“name”: “CounterStatusMessage”, “priority”: 251, “address”: 103, “rtr”: false, “pulses”: 800, “counter”: 38743648, “kwh”: 0, “delay”: 1602, “watt”: 0, “channel”: 1}
2019-01-13 12:21:44 INFO (Thread-2) [velbus] Processing message b’\x0f\xfbK\x08\xed\xc1\x03\xff\x10\x00\xc0\n\x19\x04’
2019-01-13 12:21:44 WARNING (Thread-2) [velbus] received unrecognized command 237
2019-01-13 12:21:44 INFO (Thread-2) [velbus] Processing message b’\x0f\xfb\x04\x08\xed\x02\x00\x1d\x04\x00\x00\n\xd0\x04’
2019-01-13 12:21:44 INFO (Thread-2) [velbus] New message: {“name”: “ModuleStatusPirMessage”, “priority”: 251, “address”: 4, “rtr”: false}
2019-01-13 12:21:45 INFO (Thread-2) [velbus] Processing message b’\x0f\xfbg\x03\xbd\x01\x00\xce\x04’
2019-01-13 12:21:45 INFO (Thread-2) [velbus] New message: {“name”: “CounterStatusRequestMessage”, “priority”: 251, “address”: 103, “rtr”: false}
2019-01-13 12:21:45 INFO (Thread-2) [velbus] Processing message b’\x0f\xfbg\x08\xbe \x02O.a\x06A\x82\x04’
2019-01-13 12:21:45 INFO (Thread-2) [velbus] New message: {“name”: “CounterStatusMessage”, “priority”: 251, “address”: 103, “rtr”: false, “pulses”: 800, “counter”: 38743649, “kwh”: 0, “delay”: 1601, “watt”: 0, “channel”: 1}
2019-01-13 12:21:46 INFO (Thread-2) [velbus] Processing message b’\x0f\xfb\x1a\x08\xbe \x00\x82\xba\xe0\x0e\xc5\x07\x04’
2019-01-13 12:21:46 INFO (Thread-2) [velbus] New message: {“name”: “CounterStatusMessage”, “priority”: 251, “address”: 26, “rtr”: false, “pulses”: 800, “counter”: 8567520, “kwh”: 0, “delay”: 3781, “watt”: 0, “channel”: 1}
Config file /config/configuration.yaml
homeassistant:
Name of the location where Home Assistant is running
Location required to calculate the time the sun rises and sets
latitude: 0
longitude: 0Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 0
metric for Metric, imperial for Imperial
unit_system: metric
Pick yours from here: List of tz database time zones - Wikipedia
time_zone: UTC
Customization file
customize: !include customize.yaml
Show links to resources in log and frontend
introduction:
Enables the frontend
frontend:
Enables configuration UI
config:
Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
base_url: example.duckdns.org:8123
Checks for available updates
Note: This component will send some information about your system to
the developers to assist with development of Home Assistant.
For more information, please see:
Explaining the Updater - Home Assistant
updater:
Optional, allows Home Assistant developers to focus on popular components.
include_used_components: true
Discover some devices automatically
discovery:
Allows you to issue voice commands from the frontend in enabled browsers
conversation:
Enables support for tracking state changes over time
history:
View all events in a logbook
logbook:
Enables a map showing the location of tracked devices
map:
Track the sun
sun:
Sensors
sensor:
Weather prediction
- platform: yr
Text to speech
tts:
- platform: google
Cloud
cloud:
group: !include groups.yaml
automation: !include automations.yaml
script: !include scripts.yamlvelbus:
port: ‘/dev/ttyACM0’switch 1:
platform: velbus
Hi all,
I’m using a freshly installed Home Assistant environment from Docker -> version 0.91.0
I add the following lines to configuration.yaml
velbus:
port: ‘ip:port’
In the log file, I see some Velbus related messages, which make me assume that the Velbus connection is working. I only now and then get an error message like the one below.
received unrecognized command 216 from module 192
Now I don’t see any items on my HA. Should I do something else, or should the relays/switches be automatically discoverd?
Thanks,
Pieter
since home-assistant 0.95 velbus is (almost) fully supported.
HA 0.97 will add covers/blind support to home-assistant
I still got the same issue… I’ve got a lot of velbus messages, but no items are added
still no support for the dimming modules???
as i don’t own dimming modules its hard to implement and test them …
Hey is there someone who has a working vmbgpod (glass panel button) in their velbus + home automation system?
I have been working on getting the hassio working with my velbus system, but it seems that the vmbgpod is a blocking component in the comunication…
If I disconnect it hassio works and find modules, with the module in the network nothing works…
i have it working (but only the first 8 channels) in homeassisatant
- Module VMBGP1 does not yet support sub modules
in home assistant. Any idea?
hmm, does it even support submodules?
