The strange this is that it actually worked for a short time. Any idea on how to solve this? Maybe delete the entity and let it rediscover? I would have no clue how to do that.
The problem is that temperature are unknown in HA for that module. Although it worked briefly. The thermostat function also is unavailable because of this
no, this needs to be fixed in the python-velbus lib
create a ticket there
but it worked…you sure this will be a lib error?
the above error is an error from the lib, so i’m 99% sure
alirght,were do I need to file this bug. Not sure where
Homeassistent 0.118 will have support to connect via the signum module
Quick question:
For VMBEL modules, I get a “Unknown” for all built-in temperature sensors.
Are these not supported, or is my Home Assistant acting up?
Also, is there any info on VMBPIRC and VMBPIROB modules for motion, twilight sensors?
Temperature for VMBPIROB seems to be working already.
I tried to look on the different forums and documentation, but didn’t find conclusive info.
Thanks!
Currently, buttons are represented as ‘binary_sensor’ in Home Assistant, making them read-only. However, I would like to simulate a button press from HA, so that I can reuse the actions coupled to some (virtual) buttons and the Velbus-native programs.
Is this somehow possible?
If not: I think that a new HA Service simulate_button_press, like the set_memo_text one currently available would make sense. Any chance that this can be implemented?
I’m working with Home Assistant and Velbus since last year, on a Raspeberry Pi3. I’ve more and more devices and automations and I decided to migrate on a Pi4. The HA version on the Pi3 is 2021.9.7 and the Pi4 has the last version 2021.10.6.
First of all, with both systems, it’s impossible to have a connection via the Signum or the Homecenter so I use the VMBRSUSB or The USB port on the Signum to connect.
The main problem I have now is that the name of the devices are not the name written on the Velbus modules and the same for the entities. However with the Pi3 and HA 2021-9-7 I have the good names for both devices and entities. Once I’ve had the name of the 2 first modules and nothing more, even after running the velbus.scan service. Timeout when scanning. See below…
For some glass panels (VMBGP4 and VMBGP4-2), these temperature readings are only available after the initial scan on Home Assistant. After that one temperature datapoint, no further temperature data is available. However, other temperature sensors such as VMBGPOD and VMBPIRO their temperature readings get updated frequently within Home Assistant. Within VelbusLink every module works as expected and all the temperature readings are correct for each module.
Do you happen to know why this behaviour occurs for these glass panels? Is there a possibility for me to help fix this?
do these pannels send the temp sensors on update? or regular interval?
@cereal I guess that answers my question. What is the most preferred way to send the temperature readings? IIRC HA updates its values within its database based on value changed, so I guess sending the temperature reading when values change within Velbuslink is the most optimal way?
This is the only way, velbus in HA is not polling for updates, the bus need to provide these.
So yes every module needs to send the update sensor values every X time.
This is mostly temperature, so I set this to 255 seconds, as for a temp increase/decrease this is enough.
Thank you, this indeed fixes the problem. Is there a way to embed the feedback lights on these glass panels into HA as a controllable actuator?
yes they are called ‘LED …’ but they are disabled by default, if you want them i suggest you enable these.
the background led button of the elo range is not supported (yet).
