For now, I have divided my Velbus-configuration into 7 groups of Velbus-modules.
Max 0,99 Ampère per group
I probably will create more/better groups and so taking less A per group.
The garage and garden need to be added to so …
I want to achieve a easy, cheap as possible and small Power Supply for my Velbus-modules
Is it possible to POWER the Velbus without the use of VMB3PS?
I really like Velbus, only not the way of Power Supply
A VMBxPS would be a sort of solution (x meaning more outputs i.e. 10 or 20) -
Now, why does the manual say you musn’t use one transfo (I mean a transfo with 1x12V output) to “power-up” multiple VMB3PS?
Is this specific for the VMB3PS or is there another reason? -
Can I use either a elektronical or a normal transfo? (will be using CAT5e cable for both POWER and DATA)
because electronical transfo (as I heard) have a very high pulse-frequency disturbing the DATA (and maybe bad POWER-pulses for the modules) -
I found this one. Could I use it?
videofrank.nl/psu-12v20a-18x-uitgangen-p-1199.html
Input is 220V AC
It has 12V DC output with 18 connections for 1,1A (Polyfuse 1,35A)
(I think 2x12V with each 9 connections)
I would like to connect each group directly to a connectionThis would be great to make later upgrades (like the garage)
or to power my lighting too (we use only led’s in our house) -
could I connect multiple velbus modules “directly” to following transformers?
xppower.com/orderPriceList2.php?seriesid=100515&groupid=13&catuid=1&lang=EN#pnos
I think they are electronical 12VDC output transfo’s -
Another thing came up in my mind: is it possible to place a battery or PSU as supply? (or as backup only with a relais)
Meaning a battery-charger to the 220V-net, hooked up to a large 12V battery (autobus), then all modules hooked up to battery with fuses (PSU is same thing?)
Offcourse the connections would be mounted on rails etc.
I thought the battery would be great to have a super stable 12VDC, and have backup power for when main-fuse goes out.
xx Battery gives power so lights won’t go out and you can use Velbus
xx a special relais-circuit notices when battery ain’t beeing charged --> buzzer goes off
(buzzer goes off when main power fuse is down or charger is broken)
thank you
