I’m very glad you approve
I’ve added a line in the velser-setup.sh script that will pull down the latest version of your velserv.c file from now on
For the correct /dev/ entry, you can also create a udev rule:
cat /etc/udev/rules.d/99-usb-serial.rules :
SUBSYSTEM==“tty”, ATTRS{idVendor}==“10cf”, ATTRS{idProduct}==“0b1b”, SYMLINK+=“ttyVelbus”
This will create a /dev/ttyVelbus based on the vendor and producti ID.
This was needed when I used an older PI.
It didn’t created a symlink in /dev/servial
Stef
Just a thought, but
How can we update to a newer version? As I mentioned :
But I already have velserv running, so now what…
Bernd
Hi
Once Jerome advised that he had added an update, I tweaked the install script to pull down the very latest code from Jerome’s website.
Simply running the script again will update VelServ.
However, the change is very minor and “If it ain’t broke, don’t fix it”
I know what you mean…
But I tried a part of your script:
wget https://raw.githubusercontent.com/jeroends/velserv/master/velserv.c -O /opt/velserv/velserv.c
and I got a write error. I did stop velserv before trying the update. Will your script be able to overwrite the already running/installed version?
Just me begin curious.
Hey CobleS,
what error did you get, permission denied? Try to put sudo in front of your command, so: sudo wget https://raw.githubusercontent.com/jeroends/velserv/master/velserv.c -O /opt/velserv/velserv.c
After that compile the file with : gcc -o velserv velserv.c -lpthread (or if this gives you an error, sudo in front of it)
Yeah, that’s the plan.
My installation script overwrites everything (dangerous, but true)
As Jerome rightly says, try prepending sudo
to give each command write privileges for everywhere.
However, unless you’re using an RS232 link to Velbus, the tweak that Jerome made won’t affect your installation.
@jeroends was right, I didn’t put “sudo” in front of the command
@MDAR I’m not using RS232, so I won’t update
Still good to know that I can use the scirpt if I want to update, whatever makes my life easier
i have installed velserv on a rasberrypi that also runs openhabian.
The VelServ works, the usb cable is also connected, the network connection installed in openhab. but no Velbus things are discovered.
Do these have to be entered manually or am I doing something wrong.
this is the log file in openhab:
2019-08-09 11:26:56.774 [vent.ItemStateChangedEvent] - VelbusNetworkBridgeHuis_LastSeen changed from 2019-08-09T11:22:14.117+0200 to 2019-08-09T11:26:56.730+0200
2019-08-09 11:27:56.804 [vent.ItemStateChangedEvent] - VelbusNetworkBridgeHuis_LastSeen changed from 2019-08-09T11:26:56.730+0200 to 2019-08-09T11:27:56.776+0200
this is the configuration in network binding:
Hostname or IP
127.0.0.1
Port
6000
Retry
1
Timeout
5000
Refresh Interval
60000
Hi
A quick scan with the Inbox in PaperUI should find everything (eventually).
Just to double check, can you access your network with VelbusLink, via the TCP port of your PI?
Restarting openHAB2 might do the trick.
are you sure the velserv has connection? Try to connect with Velbuslink, if that works you’re sure .The problem is that velserv exists in 2 parts, a distribution part and a gateway. The distribution part keeps running even when the gateway is down, so it could look like velserv is still running.
behind restarting openhab2 I see the following in the log:
I also requested the status of the velserv:
Curious…
This command will restart VelServ
sudo systemctl restart velserv
Please do let us know how you get on
have you’ve tried to connect with velbuslink? You can make a connection choosing the TCP/IP in the connection dialog, then fill in your ip address and port 6000. Do a scan and if you don’t get a timeout your velserv is up and running fine.
Other posibility is looking at a more verbose session of velserv. First stop your velserv service with “sudo systemctl stop velserv”. The go to the dir where the velserv program lives: “cd /opt/velserv”.
Here you can start the server manually and add some verbose options, in your case type: “./velserv -d /dev/serial/by-id/usb-Velleman_Projects_VMB1USB_Velbus_USB_interface-if00 -p 6000 -vvvvvv” and copy the output here. You can end the program with the key combination “ctrl c”. In this way you can see every client connect and disconnect + monitor the data on the bus.
succes
when I go through velbuslink I always get an error
an unexpected error has occurred, we have disconnected the bus
the ip address 127.0.0.1 is the internal loopback interface. You need to know the addrress of your openhab server where velserv is running
as I can see, velserv is running fine and I see openhab connecting and disconnecting all the time
