I have an existing Lonworks based automation system that is set up as two separate networks because of physical distancing that can communicate using LON over IP (each network has a router etc).
I’m in the planning stage of the replacement and really like the experimentation I’ve done so far with Velbus.
My question is, can I get one system talking to the other - the existing functionality I would need to replace is:
- a light switch on network 1 triggering an action (relay etc) on network 2, along with the associated feedback event.
- local triggering of an output node (such as a relay) on network 2 sending the feedback event to a switch bound from network 1
- sending of climate / daylight related events from external PIR nodes on network 2 to nodes on network 1
Would I be best use use some type of virtual relay for the output and have HAB or HA do the network synchronisation ?
