Maximum length
What is the maximum supported length for the data crossed cable between the modules? I want to install one module further away, are there limitations?
Regards,
Bart
In our building there is more than 1000m of bus cable, in every possible configuration (star, tree, loop,…), so there is no problem to have some modules a little further away from each other. Should there ever be a problem, then every module is equipped with a terminator resistor, so you can experiment with proper termination.
