is it in the roadmap to include multi-button presses…? essentially to achieve the following…
problem today: the On/Off short and dim on long press has the DIM LOW as initial action… that means if the light is already at 1% (memory) when switching on… holding the button long switches the light off almost immediately (as there is no minimum value #feedback 1) so you have to like to switch on + dim UP… you get into a fight… switch on… hold… hold… (without it switching off again)… which all in all is really annoying… (now solved by just asking Alexa to set the light at a value #OpenHab)
so ideally I would like to be able to press lets say button 1 (light source) + button 2 (dim up) or button 1 + button 3 (dim down)… for example…
that way… i can now also make nicer combinations with LED’s… where button 1 (light source) + button 4 changes the color as well…
My friend has some Zigbee 3 rocker switches that with this allow him to run 16 different channels this way making it way easier to control smart lights…
