Onewire schema
What are the various symbols to use, to represent velbus components for the onewire schema (schema to give to the external auditor that will approve your electrical installation) ?
By the way, does someone have some pictures of its beautiful installation, to post :smiley: ?
Thanks to all.
Hereby an example:
velleman.be/images/tmp/1-draadsschema.wmf
Thanks for your quick answer.
I’ve clicked on the link, but it seems that the page does not exists.
Please wait one hour for server update.
can you tell me how much push-button modules and buttons themselves are used in this 1-wire schematic ?
I’m trying to figure out how much modules will be needed to wire my complete house.
The highest D-number is 39; so I assume there will be 7 6channel input modules, unless you can also use the inputs on the relais modules to switch other modules.
How many VMB4PD modules are used in this schematic ?
VMB4PD is not represented on the schema. As far as I understand, you could even decide to not use VMB4PD. However, it is good to have at least 1 in order to do some programming like having the lights on, every monday at 6 o clock, presence simulation,…
The circle on the schema connected to the relay, represents the push button. It can be what ever you which (a button defined on the VMB4PD, a push button connected on VMB6IN, a push button connected on a VMB8PB). You could even connect a ā€œNIKO 6 buttonsā€, to a VMB8PB (see post about VMB8PB wall switch viewtopic.php?f=13&t=1372), to drive 6 independent lights. So the ā€œNiko 6 buttonsā€ here, count for 1 place in your wall.
Remark: I would use the VMB6IN for IR detector, for example.
