I did check all pdf’s but could not find any info on this.
I’m especially intrested in knowing how the atmospheric settings work using the Velbuslink.
Here’s what I want to do:
I have 2 dimmers set at mode 3 (memory function).
I have 2 buttons set to dim/toggle those dimmers by assigning the ‘Dim’ action. This works fine.
I have one button to put both dimmers off: I assigned the ‘clear’ action, which works fine.
I want one last button to put both dimmers back to their memory position. I can not find what action to assign for that. I tried ‘toggle’, but this toggles them between 0% and 100%. Is this possible?
For starting, atmospheric value is not the memorized value of the dimmer.
The momorized value can only be recalled with a switch assigned the function DIM.
For atmospheric setting, you can assign 14 buttons that each call up a different( or the same if you like ) sphere.
eg in the cofiguration panel of the dimmer you have the section atmospheric. in this section you can assign buttons that recall atmospheric setting. The first button in the collum recalls the first setting of the sphere( here you have to go to the page that assigns brightness to a button) . You have 14 settings of brightness for 14 buttons.
