It is posible to buy some component/kit that handle the protocol, and
bus interface with some input and outputs, in way so one kan make it’s
own small input and output modules, or it is planed to make some
wery small output modules
You can use the 1 or 4 channel relay modules as output modules.
As input modules you can use the 6-channel input module or the push button module.
