Each time I want to apply , I get the warning
access violation at address 00528E06 in module’velbuslink.exe’. Read of address 00000008.
access violation at address 004b8015 in module’velbuslink.exe’. Read of address 00000008.
access violation at address 00404b5c in module’velbuslink.exe’. Read of address FE3ECE06.
When I look at the Timer configuration , the timers and the 20 steps, every step has changed to S3 for When en a time given of 31:63.
All Activities are activated
and within Options, all the timers are enabled
I can change the Channel names, the response times and the LCD lines
The clock is working and does not make any error
I am using a rechargeable battery
Can someone help me?
Thank you
09-02-2010
The problem is resolved,
I was using Velbuslink 6.0 and each time I received the error messages
Today, I bought a second unit, same error message.
Then I deleted the Velbuslink 6.0 and tried with an older version, the 5.9
No error, everything went smooth as to be expected from Velleman
I think we need a new version that get rid of that problem as well that includes the temp control module VMB1TV
Till later
