I’ve been doing some work on a clients configuration and realised that there is an even easier way to resolve both their issue and yours.
Without using a virtual relay channel
So, try this logic for size…
We need two buttons (on something, somewhere, which don’t have to be visible)
One button will be for ‘SunDown’ and we’ll make it active between Sunset and Sunrise.
The other well be for the fixed times you want.
Both buttons will have exactly the same action associated with the single channel of your relay, which will be ‘Forced Off when closed’.
What we’re doing is creating two conditions where the relay channel is to be locked out.
Only one has to be active to lockout the channel, but both must be removed for the relay channel to operate again.
The real magic happens in the timer programming.
We need to create 4 timer events.
1 - The sundown button is to send a ‘Press’ signal at Sunset -this can be found at the bottom of the time out list in the top right hand corner, when setting up the timer event.
2 - The sundown button to send a ‘Release’ at Sunrise.
3 - Overnight button (8PM-6:30AM) to send a ‘Press’ at 22:00
4 - Overnight button to send a ‘Release’ at 06:30
Again, I’ve uploaded an example VLP file to have a look at.
Good luck,
{Right Click – Save as…}
mdar.eu/dl/vlp/8Pm_LX_lockoutV3.vlp
