Relais quicky on-off (pulse, simulate a button press)
To open my garage door, I need to quickly close and open 2 pins on my garage door motor, similar to a push button press. I have velbus relais modules. Can I use those?
I know how to start a timer which closes and opens, but the minimum timer time is 1 second. I’d prefer it to be as shorter.
Can this be done?
You will need a potential-free version of the relay most likely, such as VMBRYNO or VMB1RYS. Make sure you don’t connect VMBRYLD to the garage door contacts (unless the Lin/Nin on your VMBRYLD is connected to garage’s common; or your garage motor inputs are specified to accept line voltage, but that is usually NOT the case.)
I personally am using a “Momentary (follow)” action for this. The contacts will be kept closed for as long as I keep pressing the button on my glass module which is usually long enough for the garage motor to register the input.
Thanks for your advice.
I currently have the with-potential version of the velbus relay module and was thinking of connecting this to another standard and cheap relay to make it a potential-free contact. It would switch very fast, but I wouldn’t need to buy a separate velbus module for this single use case.
Do you think this would be a good idea? Or should I still go for the potential-free velbus module and just adjust my wiring for the other 3 outputs (that I will need with-potential).
That’s a perfectly acceptable solution.
The ones I use cost about €10 and have a quick swap DIL relay holder.
Wouter, enkele bedenkingen:
Een goedkoop relais is misschien minder betrouwbaar.
Als je een AC circuit moet sluiten hoef je minder op te letten met de aankoop dan als je een DC kring moet sluiten. Als je met een AC relais een DC kring bedient zal die gauw kapot zijn. De vlambogen zijn persistenter met DC.
Moet het poortcontact écht minder lang dan 1 seconde sluiten? Mijn poort wordt gestuurd met contacten die drie seconden dicht blijven, om “denderen” te vermijden. Waarbij anders de poort een open-dicht-open-dicht commando zou kunnen krijgen. Werkt perfect.
Als het écht minder dan 1 seconde moet zijn dan is het mogelijk om het Velbus contact meerdere seconden dicht te houden en met een klein extra circuitje op de uitgang naar het relais ervoor te zorgen dat het relais korter aantrekt. Doe dat echter enkel als het anders niet werkt. Hoe meer brol in het circuit, hoe meer er kapot gaat.
