I know its been a while… so trying to refresh my memory…
I have a VMBELO with on page 4 switches to power on/off some sockets on a relay… now I want to have a Green Light if the sockets are on (relay closed) and no light when the sockets are off …
I did a “monitor status of initiator” but I don’t think that does anything (and certainly does not set a color)…
I can also put a “module action” on the socket relay - changing the color of the light - but how does my VMBELO module know on which page to change / activate the colors?
Do you want the button to change the state of the relay?
Or just the state of relay to affect the “ambient colour”
A.
If you assign an action between the button and the relay channel (any action, it doesn’t matter which as long as the action causes a state change in the relay)
Then edit the Edge Light “Feedback” and “Ambient” colours for the page in question
B. (a)
You’ll need to add specific actions where the Relay channel is the Initiator and the ELO “module” is the subject.
And the action might be, “set Ambient colour while initiator is closed”
However, this affects every page, not just the page you want to see motor state.
B.(b)
A little more complex.
Set the VMBELO page button in question to “monitoring” rather than feedback.
Add an action between the Relay channel and the button, where the relay is the Initiator.
The same 0104 momentary / follow / change state of feedback
Set the Feedback colour in the Edge Lighting tab of the VMBELO configuration
