Short press - toggle (with atmospheric value) - long press is dim up
Hi -
What would be the easiest way to achieve the following
  1. press a button
  2. Dimmer goes ON to 20% (static value - not memory) or full OFF (if already on)
  3. same button long press does DIM UP
We’ve been asked this before.
I think the conclusion was that is just a tiny bit outside the scope of pure Velbus configuration.
Unless you want to use multiple actions and maybe a virtual relay.
However, it’s very easy for any of the software platforms.
