Simple program: switch on after sunset, switch off at 2 am
I want to control an outdoor light on VMB4RYLD with a simple program:
  1. Switch on 30 min after after sunset
  2. Switch off at 2 am
I assigned an On and Off actions to invisible buttons on GPOD, set up 2 programs to switch it on and off at required times.
Is this the right way do to it?
Yes. The only caveat is that programs like these can fail to work in unexpected ways if a variable step (sunset/sunrise with or without offset) and the specific time step change in order at a certain time of year.
More generally I would recommend to stick to the exact same time base for all related actions, but in your case it is hard to imagine a sunset+30min ever being past 2am, except maybe past those certain latitudes where sun never rises for half a year :slightly_smiling_face:
(You could also use a timer for, say, 6 hours instead of an On action as a safeguard in case the off action does not fire for any reason.)
Thanks! By “timer” you mean switching on the light for i.e. 4h ? That sounds better that on-off.
Edit: I think the fixed run time might require adjustments between summer and winter. Winter time I probably need 6-7h, summer 3h. I might stay with the current setup. The lamp is 2W so even if it stays on for the next year it won’t make any difference :innocent:
Yes, the right way to go.
I do something similar. For the morning: I manually switch on the indoor light if necessary. Switching off happens when a PIR sees enough light. For the evening or with dark cloudy days: when the PIR sees too little light, indoor orientation lighting is switched ON. When 2AM, everything OFF. Works like a charm for 10 years now.
And yes indeed, I had an issue with a secondary program where full illumination was automatically switched on for our hygenic assistant when she started Friday 8:15 AM and would be switched off when PIR sees enough light. Come summer time and the lights would no longer switch off. I fixed that by blocking the hidden button for 4 hours on the GPOD after the PIR sees enough light.
