I am probably a moron. But I can’t seem to figure out how to switch lights on at sunset and how to switch then off at sunrise. I enable sunrise/sunset on a VMBPOD. Then I added a program step that I should press the button that toggle the relay for 0.25sec on sunrise and then the same on sunset. But that does not seem to work. VMBPOD is set to the active program 1. But nothing is happening. Pressing the button manually works.
I can confirm that everything is uploaded to the module. Can you confirm this is the right way to do it? Do you know if there is any log somewhere to look at?
